A/C Compressor Clutch Replacement?
  • A/C Compressor Clutch Replacement?
    Has anybody replaced the clutch on their a/c compressor? Mine started going last weekend, and it looks like a new one is $330 and a rebuilt is $230, and I can really afford either right now. The compressor still works fine, so I see no need to replace it. I just want to know how bad it is to do, as I see that a clutch is $124 and a clutch bearing is $35.
    edit: can a mod put "clutch" between "compressor" and "replacement" please? I am a dumb arse
    just do the racecar mod
    !AC
      !AC
      Nope, this is my summer dd now, and my fatness doesn't like the heat
        Fixed the title for ya.
          I didnt actually do the work, but I took mine to a local place in town. Parts and labor was $160 out the door. Worked great for years after that, still have it out in the barn I think?
            there are special tools to replace the clutch but it isn't rocket science.
              Pretty simple. Just need the special tool for it. Kinda like pulling a power steering pump pulley
              2015 Silverado
                I have one you can have for free that works.
                  Parts are already ordered, but if it decides to take a crap instead, I will contact you.
                    i also have one thats always in my way in the garage. if everything falls thru, its yours
