my p/s pump took a shit on me today and it seems turn one doesnt make lt1 pumps anymore. car is going to see heavy cornering, im running a cooler but i cant see a napa pump lasting to long even given the circumstances. what does anyone suggest?
p/s pump referal
Interior Whore
- January 21st, 2008
- 6380
- fred
- 1996 Camaro z28
- U.P. and over you.
- united states coast guard
id give a napa one a shot before spending a bunch of money on it... My original unit is still hanging in there after I overboiled the original 100k mile fluid 4 times.
Is your cooler install done now? I'd like to see it, I need to get one of those on mine before spring.-Joel
Interior Whore
- 6380
- fred
- 1996 Camaro z28
no its not yet i opened the system pulling the ac, bleed and filled it properly and now its whining like nicole richieOriginally posted by JoeliusZ28 View Postid give a napa one a shot before spending a bunch of money on it... My original unit is still hanging in there after I overboiled the original 100k mile fluid 4 times.
Is your cooler install done now? I'd like to see it, I need to get one of those on mine before spring.wishing i could drive like joe and the atm squad
hahaha. Mine goes through whining spells every now and then but it tends to recover. Have you tried just driving it a bit?-Joel
Interior Whore
- 6380
- fred
- 1996 Camaro z28
I pulled it out of the garage and did a lap in the parking lot to see if would improve and it didn't seem to helo it at all and the steering feels pretty stiff.Originally posted by JoeliusZ28 View Posthahaha. Mine goes through whining spells every now and then but it tends to recover. Have you tried just driving it a bit?wishing i could drive like joe and the atm squad
- Lowell, MI
- Meat Processor
Look into turnONE (www.turnone-steering.com)
he mentioned in the first post that he called them and they no longer carry LT1 pumps.Originally posted by hoogiesngrinderz View PostLook into turnONE (www.turnone-steering.com)Doing less with more
- Lowell, MI
- Meat Processor
Whoops, I read it too quickly and thought it said "it turns out they don't make lt1 pumps anymore" My bad.Originally posted by DETROITMUSCLE View Posthe mentioned in the first post that he called them and they no longer carry LT1 pumps.
What other accesories are on the front of the motor? I run a KRC ps pump and serpintine pulley setup. I also run my hydroboost off of it. It's made to take the abuse, fully adjustable and a ton lighter.
This.Originally posted by TB2 View PostWhat other accesories are on the front of the motor? I run a KRC ps pump and serpintine pulley setup. I also run my hydroboost off of it. It's made to take the abuse, fully adjustable and a ton lighter.
Plus it's referral, sped.Joe - ATM SQUADAt the shop, watching them build my car.
Obsessed
- January 13th, 2006
- 593
- C
- It's a big pretty white plane, with wheelz, curtains in the windows and it looks like a big tylenol
- MI
- Engineer
Probably your best bet is to purchase either a low mileage boneyard pump from the same LT-1 F Car engine, or purchase one from GM. (Vette LT1/LT4 uses a different pump which is better for racing applications)
Many of the aftermarket and reman pumps are so-so when it comes to rebuilding these properly. Based on a few local "Reman PS pump" companies the contents inside are laughable, mis-matched, and hodge podge. I've custom built several for racing and laughed at what people pay for a "Racing" pump.
What exactly has been failing with your pump?
To be honest, the pump you have is darn near indistructable - you may have something else going on like a restricted line, or incorrect mounting location.
It could also be a failing belt tensioner too.
Belt Load pull on a power steering pump is Critical. You have to make sure you get a pump from the same application otherwise the pump will fail quickly and start leaking.
Many reman units have been found to mix and match applications not knowing how critical this is.
Stay clear of Napa.Last edited by TrickyTransAm; February 7th, 2012, 12:20 PM.
Turn One doesn't offer new pumps, but we do offer rebuilding services for your existing pump. Check out our website for more info, or contact us at 989-759-4206. We'd be happy to assist you in any way we can!
Wow, someone must be searching google for posts lol. But awesome customer service. Really! Fred, get ahold of them.Originally posted by turnone View PostTurn One doesn't offer new pumps, but we do offer rebuilding services for your existing pump. Check out our website for more info, or contact us at 989-759-4206. We'd be happy to assist you in any way we can!Joe - ATM SQUADAt the shop, watching them build my car.
