Best place to buy short/long block lt1?
    Agreed - I don\'t by any means feel I can 100% say one route is better than the other so I guess i should watch how I word things. This was the reply I saved in my PM box on tech, so I thought this was the most beneficial. I\'m going to leave the name out since obviously the poster intended it to be private.
    Good morning,
    I note that you\'ve received a range of responses to this sometimes touchy subject. Please allow me to offer my experiences privately for your consideration.
    By way of introduction, I build only engines that will be run on the drag strip in NHRA Stock, Super Stock, and fast bracket competition. My observations will not be particularly relevant to mild street use, blowers, nitrous, or other modifications.
    In every case that i\'ve worked on a two-bolt main block that has seen use in Stock Eliminator (no NOS, no blowers, no bull) there has been evidence of main cap movement after a season of running. These blocks see a maximum of about 7500 rpm near the end of a run. The evidence of the cap-walk is seen in the presence of shiny spots on the bottom of the main cap, sort of like freckles caused by minute shifting of the cap on the block. This seems to happen whether the cap is studded or bolted and whether the fasteners are stock or ARP. These motors have been align-honed, balanced, and carefully assembled but there is still movement. The motors live for at least 150 runs but they need to be looked at after that.
    The ONLY bottom end failures I\'ve experienced have been in two blocks that have had splayed caps installed (at significant expense). I don\'t know why these motors have failed but two of them did. There was no less attention paid to the selection of parts or assembly detail on these motors. They saw roughly the same sort of usage but they experienced bottom end problems. There are many possible explanations but it\'s difficult to isolate precise causes after a catastrophic failure.
    I have used a factory 4-bolt block (filled water jackets) in a Super Stock motor with stock caps and stock bolts (although I would have preferred ARP studs). Over five or six years that motor has seen over 400 runs at 8000 plus rpm and there is NO evidence of cap walk. I\'ve changed the bearings about every 75 runs, changed from a cast crank to a steel crank, changed pistons, camshafts, and other accessories but it\'s still the same block with the same caps. Two weeks ago, that LT1 won the ***** class trophy at the ***** national event, running multiple passes in the 10.20s at 3000\'+ density altitude. It held the **** record of 9.7xxx @ 135.xx mph in ****. I suspect that part of the answer is in the rigidity of the filled block and part is in the fact that the caps are adequately anchored through factory design but there is no evidence of cap walk.
    Bottom line, I\'ll take the factory 4-bolt configuration over splayed caps any time. And, 2-bolt caps will move around at over 7000 rpm with studs or bolts.
    I\'m sure that you\'ll take the time to review all the information presented and make a decision based on your own situation. These are my experiences and I wanted to share them with you.
    Feel free to ask questions if I\'ve not adequately explained my theories.
    Good luck.
      I like lurking and watching this conversation...
      I would however like to leave my 2 cents...
      Discard any information from anyone who has not personally been there and done it. Its funny to me how some people can get so heated in their side of the argument when they have never even done it personally.
      The even stranger thing is how everyone is always calling "bottom end this" "bottom end that". Thinking their 600 hp car is going to need a pro-mod quality bottom end. If a bottom end is assembled correctly with proper machine work then it is very unlikely that it will fail. I know a lot of you guys are unexperienced when it comes to this kind of conversation (not ragging on you), but this conversation should be about valvetrain & oiling modifications - not your bottom end.
      My above comments are just pertaining to the 2 bolt vs 4 bolt conversation... personally I think the 4 bolt splay vs 4 bolt straight conversation is just pointless at this level.
      Remember guys, its all about quality quality quality. If you have the highest $$$ rotating assembly with splayed caps with holy water running used for coolant etc it will not matter if the machine work is less than par. For example: If you get the block machined and they bore through the coolant passages for the splay converation then you now have a weaker than stock block.
      Sorry about the rant, my main point is to just listen to the experienced people who have DONE it.
        The even stranger thing is how everyone is always calling \"bottom end this\" \"bottom end that\". Thinking their 600 hp car is going to need a pro-mod quality bottom end. If a bottom end is assembled correctly with proper machine work then it is very unlikely that it will fail. I know a lot of you guys are unexperienced when it comes to this kind of conversation (not ragging on you), but this conversation should be about valvetrain & oiling modifications - not your bottom end.
        Agreed. This is why i don\'t typically voice my opinion one way or the other... its a moot point. I care about it in my build because i plan on making my engine sustain high rpm on a road course. What ryan said applies to the thread i had on tech (which i think ended up getting deleted by mods). Essentially the entire thing could have been discarded because no one had actually done it. Ryan went 9s on a 2 bolt without any problems.
          But with that said, would I have picked a 4 bolt looking back on it now... hell yes. but the 2 bolt never gave me any problems. I just also think the whole bottom end discussion is also a moot point. I think the discusssion of longevity should be about valvetrain, because that is what really matters in a high hp(especially high revving) application.
          In my eyes, its a waste of money to spend a majority of your budget on a high dollar bottom end and but a mediocre top end on it. For 99% of the people out there a studded 2 bolt LT1 with good machine work will more than suffice.
            Yep, agreed again. If i had to choose between jesel shaft rockers and a 4 bolt id take the jesels. My bone stock bottom end has been through a lot and i still have faith in it.
              pinned 6 bolt mains is the way to go..
                I prefer 8 bolt mains
                  what has them?
                    what has them?
                    I just use self tapping sheet screws on an LS block. Makes it an 8 bolt main.
                    Edit: I like your sig larry
                      I would call Adney Brown of Performance Crankshaft. He is the best engine builder in the Detroit area and well known in several magazines that cover the Master Engine Builder competitions.
                      (586) 549-7557
