Im building a motor right now, id like to know how much HP/TQ i can expect from this setup. If you have any ideas for improvements, let me know please.
60's Corvette Block bored .040 over.
Speed Pro .040 pistons.
3.48 stroke
5.7 rods
Vortec heads- P/N 10233906 with stock 1.94/1.50 with 64cc chambers. Stock springs, recommend me a set for cam below.
Considering these rocker arms- http://www.summitracing.com/parts/SCC-SCP1036BL/
Cam specs.
DURATION AS ADVERTISED INTAKE: 308° EXHAUST: 318°
DURATION @ .050 INTAKE: 234° EXHAUST: 244°
LIFT @ CAM (Lobe) INTAKE: 0.325" EXHAUST: 0.34"
LIFT @ VALVE INTAKE: 0.488" EXHAUST: 0.51"
LOBE SEPERATION: 112° INTAKE CENTERLINE: 107° IDLE VACUUM @ 1000 RPM: 11"
Running this intake with a Holley 770 cfm carb from a 68 Camaro- http://www.summitracing.com/parts/PFS-52030/
Also will be running a Mallory distributor, dont remember the P/N off the top of my head.
Will probably be dropping this setup in our S10 come spring time. May get bigger valves for the heads. Will be running a th350 for now, possibly with a 3200 stall.
Im just trying to figure out how much flywheel horsepower i can expect.
3.48 stroke
5.7 rods
Cam specs.
