Holy ****: Now what do I do?
  • Holy ****: Now what do I do?
    So, bearings were bad in my idler pulley, no big deal. I decided to get a new one and try to replace it. I was told by a few people that the bolt that holds the pulley on is not reverse threaded. Mine was. Ended up breaking that off into the assembly. Then, I didn't have a drill or anything, so I figured I may as well replace the whole assembly for 60 bucks. Still not a big deal. I had a friend pick it up and bring it to me with some wrenches to replace it. After unbolting and removing the alternator and the coolant hoses and all of the bolts holding the assembly in, my friend decides that it would be a great idea to try to break the male part (actually part of the old assembly) so that we could remove it, because the seal was preventing us from getting off. The female part, that the coolant goes into via the male part, cracked bigtime instead. I have no idea what it's called or where to get it, but after putting everything back together and being pissed, I was correct in thinking that I would be leaking coolant pretty badly. HELP please. What is this part called? Should I take it in? JB Weld it? Any advice is appreciated. Thanks
    post some pics man. I have never worked on a 3800 so I dont know the layout.
      go get a engine manual so you have a guild to work with, I am not familier with a 3800 but area you were in sounds like it might be water pump. DON"T HALFASS it identify the part and go replace it. JB weld etc will only fail later at the worst posible moment.
        I got a bunch of 3.8 pieces laying around but not totaly sure what ur talking about? the Heater core hoses? take some pix and hopefully I can help
        1998 Pontiac Trans Am LS1, Ram Air, White with custom Ghost Flames, Black Leather Interior, T-Tops, T56 Trans, 4.10 Rear End, Spohn Adjustable Torque Arm, Line Lock, Kooks Headers, Kooks ORY Pipe, SLP Loudmouth II catback, LS6 Intake, K&N Air filter, Centerforce Dual friction Clutch, Lowered and "Conklinized"
        Pioneer D3 HU, Infinity Reference 6.5 componets. Kenwood KAC-9104 1800w AMP, Kenwood KAC-8404 600w AMP, Subthump Stealth enclosure, PPI PRO104 2000 watt DVC Sub
          I'll see if I can get some pics up. It's not the water pump, but the water pump is bolted to this part also.
            Water pump is bolted to the block.
              it's bolted to the timing cover. It's replaceable. Found the part for $35...
