i have a 1995 trans am with the lt1.. i was drivin 2day and it started runnin real rough. and at idle it shakes the whole car and the battery gauge was bouncing around really bad and under any harder acceleration it pops real loud and steady. someone please help antone know wats goin on ?....fyi last year i installed a msd pro billet distributor with coil and 8.5 wires with bosch plus 4 plugs. also have headers with bosch 02 sensors.
Need HELP !!!
Regular
- December 29th, 2010
- 186
- Jamie Schnowske
- 1995 Pontiac Trans Am Ram Air WS6
- Peoria .IL
- Menards stock - Dad
Regular
- 186
- Jamie Schnowske
- Peoria .IL
they all seem 2 b ok...i did notice the back ac mount is broke and the ac wont work cood that have somethin 2 do with it ?
Regular
- 186
- Jamie Schnowske
- Peoria .IL
ok heres the lasted updates....changed air temp sensor, massairflow sensor cleaned , throttle body cleaned ,.... tried with o2 senors massairflow and air temp unpluged still doin it.....looked under valve covers looks fine dumpin alot of raw fuel out exhaust and it smells bad....backfirein bad loud... fuel presure looks ok set timing to 0. coil and icm r ok. all spark plugs were black and wet with fuel so put some new ac delcos n . im so confused anyone have any ideas ????
Post Whore
- September 13th, 2009
- 1136
- Dave Hutchison
- 1992 Chevy camaro 305 TBi, 700r4 Convertable
- Muskegon, MI
- Military
sounds like your plugs arent gettting all the juice they need. thats where i would personally start. see if anyone has a stock opti and all and see if thatll fix your problem. if your all MSD then they have to have perfect voltage. i had roughly the same issue with an old BBC i had back in HS where at idle she would run rough cause the alternator wasnt pushing enough juice to keep the MSD running at full power. check and make sure you got full volts to the opti and coil and all and make sure your voltage coming out is what it should be. im not exactly sure what the voltage should be, but make some phone calls and ask around94 V6 A4>>>>LT1 M6>>>>>>383 M6 13.1 @ 109 2.2 60' Sold/Stripped
94 Z28 383 LT1 A4 SNAPPED CRANK
1992 Camaro RS 305 700r4 Convert.
1986 Dodge Ramcharger 318 Dually Rear, Camo paint. Scrapped
1993 s10 4x4 5spd 4.3 on 31s awaiting a lift. [COLOR=rgb(0,0,0)]traded for...[/COLOR]
1998 Jeep Grand Cherokee 4.0 I6 getting 3in lift and 31s within a week or two
"Life is full of decisions, You make them and don't look back"
Regular
- 186
- Jamie Schnowske
- Peoria .IL
