gears and axles
  • gears and axles
    i was wonder what i should run for gears and axles in my 4th gen rear i got my backing plates and stuff and my axles dont seem to be in best of shape they are all rusted like a mofo and i figured while i had some extra cash i should just replace them and if i am going to replace them i should get new gears too was wondering what you all think and suggest
    auto or manual trans? your doing a 350ci motor correct?
    373's for auto 3.90 or 4.10 for manual.
      t 56 with a 383
        With a T-56 Run 4.10's there the best you don't lose any gas mileage either they just make 6th gear more useful. If they made any 4.30 gears for a 10 bolt that didn't cost an arm and a leg I would say 4.30 gears mine are great. I just happen to be selling a set of 4 channel axle shafts if you decide you want to replace them.
        01 NBM Base SS build #514 M6 Pat G/EPS 230/234 111+4 Cam, LS2 Heads, Tick Master,Extreme Chassis 8.8 with 4.30's, BMR LCA And Torque Arm, Edelbrock PHB, FIPK intake, Ported TB. Jet-Hot LT Headers TSP True Duals Tuned By SB Tuning
          You got pics n price
            IMG_20110222_152318.jpgIMG_20110222_152306.jpg$ 80 picked up
              not to step on toes. but i also have a pair of 4 channel axles i am wanting to sell.. 30 bucks picked up..
              97 TA AI 355
              2012 Jeep Patriot
                pictures and what are they out of
                  I'm going with 3.90's in my auto car when I get around to it. I would do at a minimum 4.10's in a 6 speed car. 4.56's if you are performance based.
                    any axle brand or anything
                      ill get pics tomorrow, there out of my 97 TA i think there is one missing stud.. but other than that there in good shape.
                      97 TA AI 355
                      2012 Jeep Patriot
                        Seriously? Im into 3.42s now, and really miss the 3.08s, I lost a ton of mileage switching to them, I cant imagine 3.90s in an auto car, turning what 3-3500 going down the expressway?
                          not at all, my 3.73s are not but a few hundred rpms different on the expressway. OD and lockup are your friends. I just looked it up and the rpm difference from 3.23s to 3.73s at 70 mph is 200 rpms in 4th. 2400rpms instead of 2200
                            that what my rear has now 3.23 and i dont think it will be enough
                              most defiantly wont be a good gear for a t56 with what you are planning on running. 4.10 would be an awesome gear for you to run, it will be a lot of fun as well.
