Valvetrain Set up bad?? Ideas?
    Originally posted by ThreeHonks View Post
    nothing. you should be right around 7.200" so how have you been lashign the valves if the poly lock would fully tighten?
    The only thing might be my guideplates push the whole rocker asembley up higher...i forgot about that.
    And this is how the rocker would botum out...the thread on the lock (figure 1) would botum out on the rocker (figure 2)
    Does that help? Oh and by the way thats not my motor...
      who's car was this?
      neighbors. father of the ss camaro i did
        Thanks again to everyone for the advice tho! that's why i love this community everyone is willing to give some advice!
          Here is what you need from Summit Racing for $12 .
          It is an adjustable length push rod.
          Once you set the correct pattern on the end of the valve stem then take the measurement and that is the length you need to get.
          http://www.summitracing.com/parts/TFS-9000/?rtype=10
            Thanks Rick! lol im gonna definitely get this but how do i measure it after i set it right?
              Lock the nuts on the push rod and then measure it with some long dial calipers.
              http://www.harborfreight.com/8-inch-...per-47260.html
                Thanks man...ill get them re measured
                  This site will help you check your contact pattern on the valve stem.
                  Measuring the length of a push rod is a simple process. The most important thing to remember is that different manufacturers measure push rods differently. Not all push rods of a stated length will measure exactly the same.
                  http://www.carcraft.com/techarticles...gth/index.html
                  and this site too.....
                  http://www.compcams.com/Products/CC-...rods%27-0.aspx
                    Thanks alot for this rick you have no idea how helpful this is i wasn't completely sure how to do it but this deff cleared it up!
