This concerns my winter beater, a 1995 Oldsmobile Cutlass Ciera.
Last March my winter beater died 50 feet away from my driveway. I assumed it was alternator related since all my gauges were dimming and my blinkers weren't working when I turned onto my street. Since I was so close to my house I just pushed it the rest of the way and it's sat there ever since. Since winter's unfortunately coming, I figured I'd get under the Olds and put in a new alternator. Turns out when I popped the hood, the power steering pulley had broken off and was lying in the engine bay beneath the pump, which was what caused the belt to slip off and stop charging the battery that day.
Here's the thing. My power steering has never worked since about the week after I bought the car. It would work just fine with the fluid topped off, but in less than a day all of it would leak out and even though it would dump the entire reservoir out that quickly, I was never able to narrow down where the leak was coming from. I'm plenty used to driving this piece of shit without the aide of power steering, but obviously I've got to have a pulley there so I can run a belt on it. If I just replace the pulley, knowing that the power steering still isn't going to work with just that replaced, am I asking for the pulley to just break again? If it lasted thru the winter without breaking I'd be plenty fine with that, but if it's going to crack in a month I guess I'll just replace the entire system.
Thoughts?
Thoughts?
