Explain an often misunderstood camshaft specification. Lobe seperation.........112+4
    What do you mean by what lobes? Solid or hydraulic? Its a hydraulic roller. Im so confused, lol. Eric L
      should be 2 sets of lobe numbers on the cam.
      lobes design - xer, lsr, lsk, wwf, ect....
        The end of the cam says x2371-2441-12. No lobe designation IIRC, but I will run down to the basement and check. Thanks Eric L
          I just checked the cam. The back of the cam has a 6 digit part looking number on it, and the afromentioned numbers are on the front with futral motorsports enscribed below it. I called them and got the rundown on the specs cause the last owner lost the card. We got the cam in a trade along with some AFR heads. The heads are being used on my friend Shanes E85 LT1 with a solid roller. Eric L
            by the sounds of that cam and lack of info it was spec'd for (seems old). I would get a new grind with new technology JMO
