1994 trans am fuel problem
  • 1994 trans am fuel problem
    i have a 1994 trans am with 112k
    it has 30lbs of fuel pressure at idle. seems low to me. if i give it quarter throttle it pulls strong, if i give it full throttle it falls on its face and stays at like 5,000 rpm. idk what wrong....
    is my fuel pump weak?
    is my fuel presure regulator bad?
    i know nothing about lt1's
    any help is greatly appreciated
    thanks
    Should be closer to 40 psi with the vacuum hose off the regulator IIRC. I would say your probably losing a fuel pump. Eric L
      thats what im figuring i just want to make sure to prevent going on a wild goose chase
        my pressure is about 38 at idle and 44 at wot. thats what my autometer gauge reads at the schrader valve.
          change the filter
          unplug the reg to see if the pressure rises
            update
            i have 32lbs of fuel pressure at idle. and while running when i remove the vacuum on the fuel pressure regulator it barely nudges, raises about 1 lb. is it the regulator or the fuel pump? im guessing fuel pump
            please help i need this thing running right again
            thanks
              change the filter
              what he said, and if still no help its prob your pump
                brand new filter, and it raises 1 lb when i undo the vacuum line
                  Sounds like your fuel pump is gone or is working on it
                    Fuel pump.
                      k thanks everyone for the help. i hope its the fuel pump. it barely drives, runs like shit, anything above quarter throttle and it goes slower cause runs out of fuel
