Hey guys, lately when im driving my car the ASR light, BRAKE light, and ABS light come on. I dont know what might be the reason. The person that i bought the car from said that the ASR switch is going bad, and thats the reason why the lights come on.
maybe an abs sensor is bad or a wheel bearing as the sensor sits in the wheel bearing and the magnet is not sending a good signal. Just an idea. Get a scanner on it and see if all the wheels are reading the correct speeds
I doubt the ASR switch is going bad. When it works properly it will make the ASR off light come on but not the other lights. Sounds like the car is going into a default mode. See if there are any codes in the ABS module.
abs normally wont turn the brake light on. check your brake fluid level. not sure if that has a level sensor but low fluid will turn all the lights on
Not 100% sure on the first part - if you have a lot of air in the brake lines your "ABS Inop" and "Brake" light will light up. But you're right on track with the second part - check the fluid and make sure it's properly bled.
