I have a 2001 Camaro SS with an automatic transmission. I was at a red light the other day and when I accelerated, it was bogged down and the service engine soon light came on. I shifted the car into 1st and it took off as normal. It seems that when in drive, the car is stuck in third gear. Autozone ran a check and a code popped up identifying a bad shift cylinoid which I believe is located in the valve body. Has anyone else experienced this? Do you know of a good place to have it serviced? I called the local Chevy dealership that does all the work on my vehicles and they estimated $470 for repair. It seems a bit high for draining the fluid, removing the valve body cover and replacing the cylinoid. Any info would be greatly appreciated!
Transmission Help
Easy fix!
Call transstar in livonia 1-866-248-9053 (96 service drive just past levan) and order yourself, shift solenoid a and b (same solenoid for both), a filter, and a fiber pan gasket.
Remove the pan and filter.
the shift solenoids are pointing at the trans mount 1 wire clip holds in each solenoid (you'll see when you get the pan off)
Replace both solenoids
replace the filter.
reinstall trans pan .
You just saved yourself a ton of $$$ . Total parts $ approx 50.00
Any problems you can call me at 586-255-3426.
Mike.
Thanks for the help Mike! After reading your post, it seems pretty simple and should save $400. The shop had quoted 5 hrs at $75 per hour plus parts and fluid.sigpic
Wow, nice guy! How many people would give you that info when that is there bread and butter (income).
Originally posted by 01CAMAROSS/SLP View PostThanks for the help Mike! After reading your post, it seems pretty simple and should save $400. The shop had quoted 5 hrs at $75 per hour plus parts and fluid.
They should have added udder cream to the list of materials, cause they would be milking it taking that long. Udder cream $2.99 at target.
--Double post auto merged--
Originally posted by ezcruisn71 View PostWow, nice guy! How many people would give you that info when that is there bread and butter (income).
WOW!!
I've never been accused of that before. Ask 1bad, He'll tell you that i'm a no good,4 flushing SOB.
Thank you!!
