Just bought this today.. Been wanting aftermarket rails for quite some time. My questions, how do I connect my stock fuel line to the rail and how can I run my nitrous fuel feed line off this? Or do I have to go stand alone now when I put the rails on? Come complete as shown, less the injectors..
I think you have to buy an attachment for the stock line or swap it to braided, as for the nitrous it should be pulled right off the driver side end like it is already.
That's what I was wondering, braided or an attachment.. How far back would I have to go for a braided swap, what's involved? So I should be able to buy a "T" fitting to hook my nitrous feedline in off the drivers side rail? Thanks!
they sell a AN to quick connect for that but I wouldnt recommend it. most(and even doc phil) recommend a swage lock compression fitting on the stock line.
two items that can be used to go from stock hard lines to braided. thats what i did on my car well a lot more work than you have but...
Nice, thanks.. One more question cause I am a dummy, why is there fittings on the back of both rails? Do I just block off the Pass side back since I have a single feed?
I use the Russel fitting, works great. Just got to pay attention when you slip it on that it engages all the way onto the factory line and the retainer clicks into positon.
