Ok i have a 84 firebird with a 2.8 i just changed the spark plugs but not wires i got on the freeway and when i went to 5th gear it felt like it was slipping and back firing what could this be
Help
It only does it in 5th gear?
Does it do it throughout the RPM band?Originally posted by Redd8407I WANT NOISE! SPEED! AN ENGINE THAT SHAKES MY INTERNAL ORGANS LIKE THEY GOT PARKINSON'S! I DONT WANT AN ENGINE THAT IS PARTIALLY POWERED BY MY LAPTOP BATTERY!Originally posted by Z28ISGR8WHY THE F*CK IS THERE A GOAT ON A FERRARI?Originally posted by DarrenI think it is because I take it in and out all the time, the rubber has just stretched out, especially at the bottom where it is really thin. It annoys me more then anything.
Dr LT1
- March 8th, 2007
- 8278
- Kyle L
- 1993 Pontiac TransAm V8
- Hudsonville, Michigan
- Machinest/CNC Programer
Ya, we need more info please
Post Whore
- September 13th, 2009
- 1136
- Dave Hutchison
- 1992 Chevy camaro 305 TBi, 700r4 Convertable
- Muskegon, MI
- Military
could it possibly be your shifting into 5th gear to low and its loading the tbi, carb. up with gas? thats essentially a ticking time bomb there if thats what your doing. other then that idk why it would only do it in one gear. unless you have a problem in the trans or some weird shit like that94 V6 A4>>>>LT1 M6>>>>>>383 M6 13.1 @ 109 2.2 60' Sold/Stripped
94 Z28 383 LT1 A4 SNAPPED CRANK
1992 Camaro RS 305 700r4 Convert.
1986 Dodge Ramcharger 318 Dually Rear, Camo paint. Scrapped
1993 s10 4x4 5spd 4.3 on 31s awaiting a lift. [COLOR=rgb(0,0,0)]traded for...[/COLOR]
1998 Jeep Grand Cherokee 4.0 I6 getting 3in lift and 31s within a week or two
"Life is full of decisions, You make them and don't look back"
Originally posted by 2002Z4CSS View PostIf the problem just happened after changing the plugs, check them for a cracked plug or bad wire.
If you dropped a spark plug before you installed it there is a very good chance that the insulator shell got cracked. Also if your spark plug socket does not have the rubber boot inside of it you can easily crack the insulator when installing the spark plug.It is very hard to see these cracks in the spark plug. Also check the spark plug gap and check to make sure your firing order is correct.
