Will data master work with vista cause im having trouble with it. I just installed it and can't seem to get it to do anything.when i hit record aldl data it pop up run time error 2147221498 (80040006)': overflow
datamaster help
Tags: None
sorry man i only use it on XP
I haven't used it on Vista/7 yet but I would think it should run OK. Can you try running it in a compatibility mode?- Brian Meissen
might need to get it to run in admin mode...when i had my lt1, i had problems running it, then ran into the usb to serial port converter and never got to getting a usb cable and since sold my lt1 stuff
pretty sure its right click and select properties or run as, then pic admin.Originally posted by turnerracing View PostI have heard you need to run in admin mode but i just got it and not sure how to put it in admin mode
on my desktop which is xp, so i can't check right now.
