ok..so i started buying a bunch of fuel related parts for the bird..but i got a few questions im not too sure about...
I have an aeromotive a1000 fuel pump, reading through the instructions it suggests a gravity feed..pump lower than the tank.. my fittings are welded into the top of the tank...will this be a problem? i figured it would still work properly because of the line that goes down into the tank but im starting to second guess my self now...
also..it recomends a 10an line..but the fittings on my tank are 8an..i was thinking run a 8an-10an adapter and 10an line to the fuel pump and on up to the engine bay...would that 8an-10an change cause some kind of pressure issue or no? maybe cut and drill that fitting out and weld in a 10an?
and finaly..recomends an equal pressure system...ie 10an line, y-block into 8an and one into each fuel rail, one 8an out of the front of each fuel rail and into a regulator, and finaly a 8an line back to the tank.... does this sound about right? ive never made my own complete fuel system before so im kinda in new territory, any pointers would be greatly appreciated, thanks! Caveman
