caprice lt1 vs. trans am lt1 ????
  • caprice lt1 vs. trans am lt1 ????
    i have a 94 lt1 t/a im looking at buying a lt1 out of a 94 caprice?? was wanting to build that one up.. looking to make a 383 stroker... while my motor stays in my t/a.... now my ? is...... is there any differance in the 2 motors i should know about ..... are the heads the same??? i am not to firmilure with the lt1's just getting now... i dont even know if the 2 motors have aluminium heads?? any and all help would be cool tks..
    was just wondering cuz i can get the lt1 out of the caprice for 200.00 and thought that would be worth it just to play with it ?? no??? he said it did spin a rod bearing but dont really care if im going to stroke it anyway
    the caprice engines are iron heads and the cam has slightly less lift/duration.
    fbody engines are aluminum heads.
    both 2 bolt mains, same intakes.
      Iron heads flow slightly better, however whatever performance gain would be sacrificed for the weight difference between the 2.
        The only difference I know of is that the TA LT1 has aluminum heads and the LT1 from the Caprice has iron heads. Would be a great base though.
          You could stroke the Caprice LT1 and just swap your aluminum heads over when you're done if you're not driving your car during the swap. Of course there'd have to be some time aside to do porting/polishing though.
          Used to own a Firebird.
            I wouldn't do it. For all you know you could get it aprat and it coulb be a baby Lt1. I can't remember exactly, but I think they were right around 305 CI
              Less - they were 4.3L. however that might not matter if he is stroking it anyway.
                would it make a differance if i said it was a 9c1 police cruiser i heard those have the corvette lt1's with a 4 bolt main.. would the heads be aluminium then as well ?? or not ??
