Fuel Filter Change
  • Fuel Filter Change
    I changed out my fuel filter today. Because I'd never done it before, it took me forever. You might be laughing, but this is my first attempt to do anything to my car more advanced than changing the oil or installing a new headlight. So I consider it an accomplishment.
    First I looked up how to do the job on google. Then I depressurized the fuel system by pulling the fuel pump fuse while the engine was running. Next I started trying to remove the old filter. It seems that the person who installed the old one didn't want anyone to ever get it off again. I couldn't budge the filter no matter what I tried. The wrenches kept flying off of the parts, probably because they were covered with gasoline and PB Blaster. I ended up talking to a neighbor and borrowing some line wrenches. That made heck of a difference. It's a lot easier to put all of your strength into a job when the wrenches can't slide off so easily. Once I got the filter loose I held one bolt with a wrench and turned the filter using a pair of Channel-Locks. Putting in the new one was a piece of cake. I made sure not to tighten it so much so that I don't kill myself again next time.
    Two hours, two sore arms and half a can of PB Blaster later, I'm happy to report that the new one is securely in place. Although it was a major pain, I'm glad to have done the job as the gas that came out of the old filter was the color of used motor oil.
    Anyone else ever have trouble with this job?
    -BK
    1998 Pontiac Firebird 3.8L 5spd
    Great job, it always feels good to accomplish new things!
    Next time, try depressurizing the fuel system by turning off the car and relieving the pressure at the schrader valve on the fuel rail.
      Someone else gave me that advice as well. I tried it but nothing seemed to happen. I pushed down on the valve with a screwdriver. No luck. Rather than messing around with it I just used the other method. I'm sure I was doing something wrong.
      -BK
        Why would we laugh? At one point all of us started learning mechanics and started with things like fuel filters and brake jobs. It gets very addicting though. This year its a fuel filter but next year it will be an engine swap. Trust me, I've been there....
          Brakes are actually my next task. I'll probably give myself a weekend for that though. We'll see. Still thinking about it.
          -BK
            just curious why u depressurized the fuel pump or do the Schroeder Val? If you don't mind a bit of gas leaking you could have saved a step and just undid the fittings it may have leaked 1/16 of a gallon lol.
            LS6 cam, LS6 valve springs, built tranny w/ 3k vigilante converter, 160 t-stat, SLP exhaust and headers, HAL suspension and go-fast juice
              Some of those tasks can appear quite simplistic. . .but in the end, can be very excruciating.
                Two out of the three procedures I read on the internet had the depressurization listed as the first step. I just assumed that it would make the gas leak out in a less intense fashion. Some gas did leak out, but it was only a dribble. So I don't know if it was necessary or not.
                -BK
                  He did the job the proper way.
                  Good job man. Its a step in the right direction.
                    yea i never depressurise it but only for time savings. its a mess and then i smell like gas all day. try it on some of the olds and buicks, its wedged between the gas tank and truck well. its a fun time.
                    brakes arnt too bad, a few of my non car guy freinds have done it and said afterwords that it wasent too bad. aslong as every thing comes off nicely that is.
                    Sold!
                    www.fquick.com/lozanoa11
                    94 Grand Cherokee (sold)
                    95 Accord(for sale)
                    99 Outback (snow destroyer)
                      yea but you can do the easy way in half the time...besides you lose such a some amount and mine hardly leaked...maybe i got lucky...who knows
                        Congrats, Brian! I still have to change mine at some point.
                          Good job man! might i suggest someone looking over your shoulder when you do the brakes. they're pretty straight forward, but they are a safety issue. wouldn't want something to go wrong.
                            Buy the parts ahead of time and head out to my place. It's a 40 minute drive from your town but I can show you everything step by step. I like teaching people new things. I'm ASE certified in brakes so I'm sure I can teach you one or two things. If you're interested you can shoot me a PM and I'll give you my number and address.
                              I've never wasted my time depressurizing the system either. Sure, it's a little messier, but I charge flat rate and every minute saved is a $ earned You're going to loose a little gas anyway and if you take the line loose slowly the stream is usually fairly controllable. I look at it as a chance to use some of the would be wasted fuel as an added chance to clean some of that semi-permanently, embedded crud from under my nails.
