Need help with Pontiac 455 alternator brackets
    im as direct as can be,
    get that thing right its time to cruise woot
      getting there its getting a small body lift because the rear tires rub when you hit a small bump. Then i have a new carb going on and being tuned and dynoed then she will be ready to go for cruises!
        screw the lift do what im going to do, adjustible shocks to stiffen to a safe desired ride, mine hits since i put the car so low.
          Yeah mine it and put a small cut in the tire i dont for see that safe for highway use!
            i dont think that its possible to do a body lift on a 1st gen?
            possible options:
            re-arch the rear springs - probably sagging
            replace rear springs or add blocks
            air shocks
            taller shackles
              possible options:
              air shocks
              taller shackles
              Yeah i got taller shackles but now i have to change the exhaust casue the shackles are where the exhaust was.
                even though i used them back in the day im not a fan of shackle replacement - especially on a vehicle thats putting any really power down
                check into the re-arch or maybe adding a leaf
                2nd choice would be air shocks
                  Where can i get air shocks?
                    you might try monroe?
                      Who is that i am new lol
                        I'm sure Creight, one of the site sponsors (main page...top right corner), can get 'em...maybe the easiest solution...
                          Yeah i found a new set on ebay with a 90 day warrenty for 70 bucks should of asked creight first though.
