Free mods
  • Free mods
    I've done a search for free mods but I didn't get anything close. Nor do I know what they are. A little help please. its going to be 40-50* this weekend and and I would like to be spending time in the garage. thanks
    SLP lid, smooth bellew, Kateck valve covers, Trextralia 700oz clutch, Pro 5.0 shifter, SLP loud mouth cat back. Torque Thrust M
    TB coolant bypass
    http://www.ls1howto.com/index.php?article=13
    98 Trans Am WS.6
    Cam
    Heads
    Intake
    Full exhaust
    More mods to come
      Throttle body bypass
      Free ram air
      Bumpstop mod
      There are more than that to. A simple search on LS1tech would help your cause a lot
        Free ram air
        Bumpstop mod
        What's the Bumpstop mod?
        98 Trans Am WS.6
        Cam
        Heads
        Intake
        Full exhaust
        More mods to come
          the tb on most ls1 only opens about 78* stock you cut away part of the bumb stop allowing the tb to open closer to 90* its a good free mod dont cut past 90* or youll throw a check engine light
          01 NBM Base SS build #514 M6 Pat G/EPS 230/234 111+4 Cam, LS2 Heads, Tick Master,Extreme Chassis 8.8 with 4.30's, BMR LCA And Torque Arm, Edelbrock PHB, FIPK intake, Ported TB. Jet-Hot LT Headers TSP True Duals Tuned By SB Tuning
            heres the link for the tb bump stop
            http://www.bowlingss.com/Mods/Instal...Stop%20Mod.mht
              I'm definetly goin to check my car tomorrow to see if that's been done. I don't have a scan tool though to do it myself if it has not.
              98 Trans Am WS.6
              Cam
              Heads
              Intake
              Full exhaust
              More mods to come
                I also found on LS1howto.com how to port the TB. Not too hard, this is what they said about it.
                First do some preliminary porting, making sure you DONT port right at the opening where the blade contacts when shut. Grind down the ridge thats about 1/2" in front of the blade and try to smooth it all out. Then, use JB weld to fill in the big port making sure the epoxy gets DEEP into the hole and wraps around inside the hole so once it sets, it can never fall out. Let it dry, then smooth the epoxy out and drill the hole in the epoxy for the PCV hose. On an F-body, you'll need to drill two holes. The Ybody only needs one.
                They also had pics, you can see them at the website.
                98 Trans Am WS.6
                Cam
                Heads
                Intake
                Full exhaust
                More mods to come
                  id think you would be able to do that by eye just as long as you dont over do it, just a few degrees below 90 t be safe without the tool, but maybe the autozone engine scan tool and check to see how far the tb is open, if you have an autozone or a auto store with the free scan tool. somethin to look into since its a free mod lol
                    You don't need a scan tool all you need is a multimeter.
                      What's the free ram air Mike????
                      99 Camaro Z28 A4
                        I'll show you next time I see you.
                          a leaf blower,
                            Also the EGR tube mod, where you cut the piece hanging in the intake right behind the throttle body so it is not blocking the airflow. Just don't cut too much off.
                              or you could just remove the AIR and EGR entirely and get block off plates. The free ram air mod is cutting out a couple of slots underneath the filter.
