LS1 swap into the IROC underway
  • #46
    Thanks Eric.....I think I am going to avoid the bling for awhile. While having all that stuff polished looks nice, it's a lot of work to keep up when you drive the car alot......and that's what I am going to be doing....driving the snot out of it..... Can you say PowerTour!
    • #47
      Originally posted by transampimp
      .....I'm going to miss the polished intake from your last motor.....
      It'll still be around.
      Originally posted by WMCCJames
      .....While having all that stuff polished looks nice, it's a lot of work to keep up when you drive the car alot......and that's what I am going to be doing....driving the snot out of it..... Can you say PowerTour!
      for Power tour. I you ever have polishing withdraws feel free to stop by.
      By the way the car is looking AWESOME.
      — Thomas Jefferson
      • #48
        Looking good James.
        • #49
          Here is that Autometer adaptor used for the oil pressure sender....worked out slick after using a factory GM pressure "T"
          • #50
            Two become one......can I have a moment of silence.....thankyou. Just making sure the trans will fit into the clutch before seperating them again for the install.
            Check out my 6061 billet aluminum torque arm mount. I made this a few years ago when I did the first T56 swap into my car. I CNC'ed this at work one day....shhhh
            Motor going back in for the final time!
            • #51
              looks good james
              • #52
                Anybody know what goes here?
                Just need a strong helper to help me wrestle in the trans...any takers?
                • #53
                  thats where the t56 goes
                  • #54
                    '73 Z28 388 Stroker, M22 Rockcrusher 4 speed
                    WMCC Photographer and owner of Redline Photography
                    You are only young once but you can be immature your whole life!!!
                    • #55
                      Lookin good James !
                      Sharin The Sweet Life!
                      3rd Gen's Rule-
                      • #56
                        Hey James,
                        If I didn't have to work tonight, I'd be happy to give you a hand in putting back the "Heartbeat" in your Camaro.
                        Lookin Good!
                        2013 Stage II Nickey Camaro Convertible #10
                        Special Edition
                        Red Magnuson Super Charger w/a rear cog drive, ZL-1 fuel pump, Nickey cnc ported heads, Nickey spec. custom grind cam, Roto Fab CAI, Kooks LT's, No Weeds dual mode elec. diverters, Pedders eXtreme XA Coilovers, Pfadt ZL Spec sway bars, 20" AR Torq Thrusts wheels w/ polished billet Nickey centers, Nickey pistol grip shifter, upgraded 1400hp rear axles, 800hp @ the crank, 670RWHP w/613ft. lbs. of torque @11 lbs. boost! Check out album for pics!
                        • #57
                          caugh*woman*caugh, JK i've done a few T56 R&R's by myself on my back in my garage with the car only about a foot and some change in the air...trick is slide the trans under the car, lift the back of the trans up and slide a floor jack under the trans....get the jack at that "magic" balance spot...then use your leg to pump the jack up...and wiggle to your hearts content until it goes home.... worked the same way when i R&R'd a T56 on my buddy's C4 TCC (racecar)...we did it twice in 2 days!
                          1998 Camaro SS Bullseye Turbo
                          • #58
                            what do u want a cookie or something?????
                            j/k
                            • #59
                              I can help you sunday James, just let me know!
                              • #60
                                yeah...I've done it too...and it's just plain stupid to do it that way. I had the trans roll off the floor jack while doing it that way, thank god my fingers were out of the way! Maybe I'm just getting older and wise now, no sense taking that kind of risk.
