ls2 6.0 swap 370CI or 408CI
  • ls2 6.0 swap 370CI or 408CI
    What is needed to take a stock 6.0l block ls2 and make it a 370ci or a 408ci motor?
    Lots of $$$$. Stroker crank rods pistons
    When in doubt, Whip it out !
      370 is stock crank. 408 is 4" stroke crank. Depending on goals, there's no reason to run the 408. Stock crank is good for over 1000hp
        LS2's are normally 402/403 - to leave some meat on the cylinders.
        Iron 6.0's go 408.
        2000 Formula
        fixed slow junk
          Eh just build this.
          http://ls1tech.com/forums/dynamomete...-1000hp-n.html
          Originally posted by Yoshi94
            To get a 6L out to 370ci take boring it .030 over. This would require resleeving it correct, being that a LS2 is an aluminum block that has iron sleeves? Same with the 408, its a 4.00" stroked 4.030" bore.
              I think the aluminum block can be bored out .030 with out issue. Correct me if I'm wrong
                you are correct, no resleeving necessary.
                  Are rod sizes still the same 6.125"?
