I'm working on building a new short block for my M6 97' Z28 and started kicking around the idea of stepping up to a stroker. My initial plans were to re-use a stock crank and add forged rods, pistons, ARP everything, etc. My engine builder suggested going fully forged and then I brought up stroking it. My goal for the build is to be a reliable street/strip cruiser and keep it somewhat budget. I don't want to replace too many parts I already own so I was wondering what you think my limitations are. I would be happy with around 450hp/450tq (at the engine) and don't think I would be too far off. Besides putting $1k in port work in the heads where do you think i'm leaving extra hp on the table? Should I use a bigger cam? I don't want to spin it much over 6,600 rpms becuase of the Opti. Would the heads benefit from bigger valves without additional portwork? Get the intake ported?
Heads
Intake/Exhaust
Camshaft
Misc
Heads
- Re-machined stock valves
- Patriot Performance Gold Dual Spring Kit, .650"
- ARP Cylinder Head Bolts (12-Point)
- Trick Flow Pushrod Guideplates
- ARP Rocker Arm Stud Kit (7/16")
- COMP CAMS PRO MAGNUM ROCKER ARMS SBC 1.6 (7/16")
- GM Performance Hydraulic Roller Lifters
- Milled 20 thousandths
- Gasket matched
Intake/Exhaust
- LPE Cold Air Intake
- Trick Flow LT1 Air Inlet Elbow
- 52MM TB
- Long Tube Headers - Emissions deleted / EGR Block off plates
- 3" ORY
- Hooker Cat Back w/ 3" Cutout
Camshaft
- Advanced Induction 226 / 234 - .567" / .567" - 110 LSA
- "Easily our most popular daily drivable grind for 350cid applications. Typically makes peak power at 6300-6500rpm on 350-355cid short blocks.
Properly tuned it will run and drive well in M6 cars w/ stock gearing. A4 cars should run a 3.42+ rear end gear & 2400 rpm converter minimum.
Can pass emissions in some states."
Misc
- March Performance Pulleys
- LT4 KM
- MSD Coil
- MSD 8.5mm Super Conductor Spark Plug Wires
- 30lb modified Bosch 3 fuel injector set
