1995 Camaro V6 3.4 Full engine swap. It will start, idle rough and then die. Everything has been replaced on this thing and we are at a total loss as to whats wrong. Any insight would be greatly appreciated!!! HELP!
1995 Camaro V6 Full Engine Swap Trouble
Obsessed
- September 4th, 2006
- 740
- Syd
- 1998 Camaro "Cam" v6 5 speed (sold) 2009 Jeep Commander, 2011 Ford F-150
- Bloomington, IL
- Vet Tech & Oil Lube Tech
sigpic~*Sydney*~734*883*788698' CAMaro V6 5*Speed (sold)TEAM EMTC : MiT/A'96 / tenpin842 / jadair / Yargermeister -
So it's still a 3.4L v6 or you swapped in an LT1?- Brian Meissen
Obsessed
- 740
- Syd
- Bloomington, IL
Its still a 3.4 v6. Its barely running at idle. But you can rev the motor and it smooths out at increased RPMs. Since the swap we've put in new cam and crank senors, new plugs, wires, had the ignition module tested and it tested fine and a new map senor.sigpic~*Sydney*~734*883*788698' CAMaro V6 5*Speed (sold)TEAM EMTC : MiT/A'96 / tenpin842 / jadair / Yargermeister
- Greenville, MI
- Die Maker
Have you checked for a vacuum leak?
Obsessed
- 740
- Syd
- Bloomington, IL
The muffler has some small holes on it but there no leaks on the motor itself. I didn't think the muffler would cause the rough idle. It's extremely rough. Planning on replacing the muffler and exhaust in the future once we get it running.sigpic~*Sydney*~734*883*788698' CAMaro V6 5*Speed (sold)TEAM EMTC : MiT/A'96 / tenpin842 / jadair / Yargermeister
- Greenville, MI
- Die Maker
Leaks on the exhaust side past the o2 sensors wouldn't cause it to run rough.
My first guess would be unmetered air. Cracked air intake behind the MAF (don't remember if the 95 3.4 had one) or a vacuum port is unplugged - brake booster, PCV valve, etc.
Obsessed
- 740
- Syd
- Bloomington, IL
No leaks on the motor, no mass air flow senor. Does have an air temp senor, didnt replace it. Didnt think it would cause these problems but not sure now. We're at a loss.sigpic~*Sydney*~734*883*788698' CAMaro V6 5*Speed (sold)TEAM EMTC : MiT/A'96 / tenpin842 / jadair / Yargermeister
Lurker
- March 13th, 2010
- 3476
- TJ
- 1995 Chevy Camaro Z28
- Clinton Twp Michigan
- Powerline Tree Trimmer.
IAT and Coolant sensors would play havoc with Saturns.
Take some carb spray and spray it around the top end. If the RPMs pick up you have a vacuum leak.
Stock cam or did you pop in a bigger chopstick?Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
- Greenville, MI
- Die Maker
Yup, a bad coolant temp sensor will cause more problems than a bad intake air temp sensor.
You can try unplugging one at a time and see if there is a change. I bought a 93 van with a bad coolant temp sensor, it would start cold but then run rough as hell when it warmed up. Didn't even restart when warm because it dumped so much fuel. Typical GM sensor will read high ohms when cold so if it goes out (not shorted) it will increase fuel, adjust timing/egr/evap/etc. at all engine temperatures
