As of last night i found that i cracked the heads on my truck, my friend has a set of tbi heads from an 87 suburban but if i can stay away from tbi heads itd be great, so does anyone have a ready to run set they are willing to part with on a limited budget, or just want to get rid of preferably by tonight?
anyone have any sbc heads they want to get rid of
Post Whore
- November 8th, 2009
- 3000
- Tyler Porter
- 85 Z28, 91 Trans am
- Clinton Township Michigan
- student
00 Tahoe Z71........Stock
97 K1500 lt4 cam, 1.6s, MPFI, Solid axled, IROKs,------winter beater -
Post Slut
- December 9th, 2011
- 5919
- Michael H
- Greenville, MI
- Die Maker
Center bolt or perimeter?
Post Whore
- 3000
- Tyler Porter
- student
the heads center i believe they have bolts betwen each rocker plus the ones down by the manifold91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
Post Slut
- 5919
- Michael H
- Greenville, MI
- Die Maker
Umm...all sbc heads have the bolt locations there.
Center bolt or perimeter applies to the style of valve cover. Center bolt is 87+ which means the four intake manifold bolts are angled differently. I assume you want to keep the stock intake manifold for the time being.
I have the ones off my 350 TBI or the 69 double hump heads I have sitting on the shelf as well
Post Slut
- 5919
- Michael H
- Greenville, MI
- Die Maker
Post Whore
- 3000
- Tyler Porter
- student
guy didnt answer, left him a voicemail. dont think i can spend 200 bucks on heads right now since i already sunk a ton into the engine anyways. darren arent fbody tbi heads the exact same as my trucks tbi heads?91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
Post Slut
- 5919
- Michael H
- Greenville, MI
- Die Maker
You won't find good heads for less than 200. Those things are zero miles, 2.02/1.60 valves, 76cc chambers. It cost about 300 just to freshen up a set of heads!
The TBI heads are still on his motor I think. And yes, probably the same. For what it's worth, I just chucked a running set into the scrap metal pile this winter.
Obsessed
- December 28th, 2005
- 931
- Friends call me Cat.
- '87 305 IROC Z Bride nick named my ride as "The Ole Whore". IDK, jealous maybe?
- Jackson
- Civil Servant
I have a set of heads laying around that came off my '87 IROC. If ya want 'em, come and get 'em, they're yours for free. Well, yours for the cost of the gas you'll use coming to get them. I'm tired tripping over them.
Interested? Shoot me a PM.
Cat.
Post Slut
- 5919
- Michael H
- Greenville, MI
- Die Maker
There ya go, Tyler. LB9 heads work pretty well with some mild porting (focus on exhaust side) and should bump the compression a bit. Valves are a little small at 1.84/1.50. They will handle the LT1 cam just fine.
Post Whore
- 3000
- Tyler Porter
- student
i sold the lt1 cam ill have to find another, gotta find a day when i can take a trip out to jackson and maybe delay my repairs91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
I just threw a pair out damnThe Original
Post Whore
- 3000
- Tyler Porter
- student
i think this happened with something else before jon91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
Post Whore
- 3000
- Tyler Porter
- student
id like to keep my stock intake, but if this one deal falls through then i guess i either go stock or curts vortecs91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
