I'm hitting a wall here. I have a 1989 siverado with 98 GMC metal, older 350 crate motor, 6" lift, etc.
I pulled the carb setup off, switched to a TPI with the serpentine setup. I used the harness from my 89 Camaro TPI, 165 ECM, used 22# injectors (off a running motor, so I was told), cold start is there but not wired.
The thing will fire for a second on starting fluid. New Walbro 190 fuel pump, 48 psi while the pump is running and pressure drops to 42 when it shuts off. Bleeds down rather quickly though, faster than I'd like (1 psi/sec). I put a noid light on the injector banks, clip was hooked to positive (constant 12v) and the probe into the left/right bank pin on the ECM. The light is on when the key is off, shuts off with the key on, flashes during cranking. Assuming the ECM grounds the circuit to fire the bank, it should be firing the injectors. Correct? The solid black injector wires do have 12v when the key is on.
I forget what the injectors should ohm out at, on bad one could possibly kill the entire bank I assume. Varnished injectors? I did buy them used for 15 bucks. The chip is an '89 305 AT, cold start isn't hooked up, but that should allow it to at least fire for a few seconds w/o ether...even if VATS were to cut fuel. My dad keeps saying 180 out on the distributor...but I'm almost positive I put the new dizzy in pointing in the same direction.
