Wiring Help
  • Wiring Help
    So my latest project is Putting a LS1 from a 2000 Trans Am into a 99 Firebird. As I have the donor TA (Thanks to Camaro42 I purchased his dads wrecked TA) I am going to swap over the Fuel tank and lines and the pedal assembles as the 99 3.8 is fly by wire. From the research ive been doing the interior wiring is the same so i shouldnt have a problem but there is a few differences in the engine bay wiring. I have found the Diagrams for the 00 Trans Am but cant find a diagram for the 99 firebird does anyone know where i can get it? Also if anyone has experience in this what do I need to do to get the cruise control to work. I have the modules from the TA but am I going to need to rewire it? I would just swap the engine bay harness and call it good but the harness is damaged and i think it would take more effort repairing it than it would to add the few wires I need to make everthing work with the v6 factory harness.
    Here are some Pix of the project so far and any advice would be greatly helpfull.
    IMAG0317 (Medium).jpgIMAG0314 (Medium).jpgIMAG0320 (Medium).jpgIMAG0318 (Medium).jpgIMAG0316 (Medium).jpgIMAG0315 (Medium).jpgIMAG0321 (Medium).jpg
    1998 Pontiac Trans Am LS1, Ram Air, White with custom Ghost Flames, Black Leather Interior, T-Tops, T56 Trans, 4.10 Rear End, Spohn Adjustable Torque Arm, Line Lock, Kooks Headers, Kooks ORY Pipe, SLP Loudmouth II catback, LS6 Intake, K&N Air filter, Centerforce Dual friction Clutch, Lowered and "Conklinized"
    Pioneer D3 HU, Infinity Reference 6.5 componets. Kenwood KAC-9104 1800w AMP, Kenwood KAC-8404 600w AMP, Subthump Stealth enclosure, PPI PRO104 2000 watt DVC Sub
    I have all of this info, txt me after 6pm and I should be able to get you everything you need. Also, see my 2 build threads, I have already done everything your doing. Once with a 5.3 and once with a 6.0
