it looks pretty sweet flat black.
and the swap begins
InActive Member
- December 1st, 2005
- 1208
- Jeremy
- 1978 Pontiac Firebird Formula
- Dorr, Michigan
- Fence Installer
Holley 650cfm Double Pumper
Edelbrock Performer-Plus Cam
Originally posted by kammi10yep well a little update. the only bolts left holding it in at the motor mounts and im waiting for someoen to help me pull it and then its good by 305
Let me know if you need help. Im at work right now, get out at 2:30, and im already in Wayland.
Edit: Might be working longer & might not be able to come out today.Last edited by MattODoom; July 1st, 2006, 11:45 AM.
update. engine and tranny are out. engine bay cleaned for the most part. car is gonan be moved to the other garage where the new shit will all be put in. in about 15 minutes.
just gotta clean it a lil bit first
pics commin in a few too
you da man!!! that's kick ass....by far one of the cleanest third gens period, and on top of that, a fine motor to accompany it! good luck with getting it wrapped up! im sure it's gonna sound mean as hell once you get it run'n again!!!
1998 Camaro SS Bullseye Turbo
looks kick ass man! good job thus far!1998 Camaro SS Bullseye Turbo
i got one from summitOriginally posted by MattODoomWhat did you end up getting for a dizzy?
http://store.summitracing.com/partde...0&autoview=sku
it was recommended to me from someone on thirdgen.org
wow that looks awesome!!-Joel
there just set on there the intake nor carb is bolted down but as it looks im gonna be runnin a stock hood instead of a cowl
