LS1 Swap
  • Gottork
    replied
    Thats awesome!!!! I am kicking myself for not POR15 the bottom, but will be glad none the less to redo it completely in a few years
    Leave a comment:
  • ktl711
    replied
    Beauty, eh!
    Leave a comment:
  • Emulsifide
    replied
    Update:
    Started with this:
    After washing it FIVE times including twice with acid to etch it for the POR15 treatment, I finally ended up with this:
    Tomorrow I can finish up the rear brake lines and then start dropping the rear suspension into the car.
    Leave a comment:
  • MP81
    replied
    All right - and I agree with the buying tools part, it's awesome!
    Leave a comment:
  • Emulsifide
    replied
    I have a set you could borrow, if you don't want to buy them.
    Thanks Kyle, but I LOVE buying tools. lol. If I can't find what I need, I'll let you know.
    Leave a comment:
  • MP81
    replied
    Originally posted by Emulsifide View Post
    Thanks guys!
    So I got a neat little box in the mail from Jegs, the only place that had the damn thing in stock:
    Lots of little parts (96 to be exact). Per rocker, you get two complete needle bearings, a lighter (and assuming stronger) trunion, two c-clips, and a Fuller Metric YFS 12.9 hardness shorter than stock rocker bolt.
    I was pretty worried about putting these things together because you do need a press of some sort (I returned the press I bought from Harbor Freight during the PowerDyne project). Thankfully, the previous person that owned my house was an avid car guy as well and left behind a big honkin vice.
    Removing the old trunions was a matter of finding the proper size sockets to use in the vice (7/8" and 13mm). The same goes for installing the new trunions (3/4" and 16mm). Here's a picture of the new trunion pressed in:
    After a couple of hours (I tried to be super careful), I ended up with this:
    Upgrade complete! Now for the snag of the night.......
    The new YFS bolts are hex head and I don't have any hex head sockets to use with my torque wrench to install the rockers!!! Gah!! At least it's a good excuse for me to buy more tools tomorrow.
    That's it for tonight. I didn't get anywhere with the rear end yet due to feeling a bit under the weather the past 24 hours. Tomorrow, the engine will FINALLY be completely buttoned up.
    Leave a comment:
  • Gottork
    replied
    loving it, keep up the good work
    Leave a comment:
  • ktl711
    replied
    You're gettin' there, man! This is gonna be sweet!
    Leave a comment:
  • Emulsifide
    replied
    Thanks guys!
    Leave a comment:
  • MP81
    replied
    Sweet build!!
    Leave a comment:
  • Gottork
    replied
    Leave a comment:
  • esoteric18
    replied
    Jeese lol amazing work so far. This is my bible for when I finally get my 408 fully assembled aswell as all the other work needed.
    Leave a comment:
  • Emulsifide
    replied
    The fuel tank is up!! Here it is before it went in the hole:
    Of course, I couldn't go with just a stock fuel pump. In the tank is a Racetronix fuel pump and attached to it is their upgraded power harness.
    For the time being, I've decided not to waste my time making new fuel and evap lines. I had a guy ship me a set of nearly new lines, but he had to bend them up to get them into a box. Thankfully, none of the lines he bent up had any hard kinks in them, so I was able to straighten them out pretty easily. The evap, fuel, and new stainless brake lines were mounted onto the car a few weeks ago. Tonight I was able to hook them all up in the rear:
    I also flared the front of the line and attached it to my Wilwood proportion valve:
    I'm not sure I like the way SJM bent the front lines. I might redo them and make the proportion valve sit behind the shock tower hump underneath the brake booster. Regardless, the rear brake line is finished!!
    Might I also add, the Mastercool flaring tool is by far the best damn flaring tool I've ever had the privilege of using/owning. Here's my first inverted 45 degree double flare:
    Perfect every time. It's impossible to screw it up.
    That's about all I could get done in the two hours I had to work on the car tonight. I need to start working on the rear end (axle) shortly. I plan on cleaning the nasty thing, welding on the lower control arm relocation brackets, and then painting the whole thing with POR 15. That will probably be tomorrow's project.
    Leave a comment:
  • Emulsifide
    replied
    Thanks for all the great comments everyone!!
    Here's a pic of the car when I was prepping for a heat exchanger when I was working on supercharging the 3800:
    The picture was shortly taken after the car's first round of Zaino treatment.
    Leave a comment:
  • Lucky SOB
    replied
    Originally posted by ktl711 View Post
    There's an "in-process" 3/4 front shot of the Camaro on Page 1, Post #29 of this thread, about 1/2 of the way down. Bright Rally Red Camaro coupe, no T-tops, crank windows, V6 & M5 originally. Very clean car to start with.
    Thanks Kevin, Post #29 is one heck of a post too! lol
    Leave a comment:
