You really shouldnt have needed the interior harness. They should be the same 97+, but w/e.
The cheapest/easiest/cleanest way to make your fuel system work is to buy a fuel filter from a 2001 vette. It has an integrated pressure regulator in it. Replace the factory fuel filter with this one, then take the return from the tank and attach it to the filter/regulator. You can then remove the v6 return line that runs up to the engine bay. The v8 cars work basicially this way, the regulator is just in the tank. The fuel pump it self is the same. Ill get you some pictures tonight if I can.
Also if you can get the funds together, cam it and do anything else you want before it goes in the car. It is SO much easier.
If you have any other questions shoot me a PM.
EDIT: Just thought Id add to your shopping list.
LS1 radiator
LS1 coolant tubes, the hoses that run to the heater core. They are aluminum, dealer only, and stupid expensive. Head over to ls1tech and look for someone parting a v8 car out. I picked mine up for $30, vs almost $250 the dealer wanted.
All other radiator hoses
Front springs and shocks
ls1 battery cables(if your engine doesnt come with them) $160, dealer only, PM me if you want to know how to modify your v6 ones to work.
Im also 99% sure youll need a new cluster, anything 99+ from a v8 auto car should do. 98 all the wires from the gauges were sent to the cluster individually, where as 99+(supposedly) the data for all the gauges was sent over the serial data bus, i.e. 1 wire. I used my factory 99 v6 cluster, with a 2002 engine and a 2001 engine harness, everything works and is accurate except oil pressure, which works, just reads wrong.
I spent a good amount of time looking at wiring diagrams while I was doing my swap, so pm me if you want any help.
LS1 radiator
