Yet another issue has appeared with the ongoing change over of the 94 TA engine and the rest of the "guts" into the 99 Firebird.
We are using the 94 complete brake system -less the 94 calipers. Instead we kept the 99 larger rotors and calipers on the car (Yes, swapped the rear backing plates, the front spindles etc).
Master cylinder was bench bled, then we bled the ABS unit (front most bleeder first.) Then the front brakes at the caliper. Without the scan tool, we then drove the car over three miles an hour to cycle the abs like we've read can be done on the net.
Front brakes dragged the whole time. Once back in the shop we then bled the rear lines. Unhooked the battery to reset computer, then tried a test drive -it would barely move!
All four disks are locked solid, the car is a huge non rolling brick now!
One other issue has come up while trying to figure out the brake issue -when we installed the booster and master cylinder in the car (we have both complete sets from the 94 & 99 both look identical as far as push rod lengths sizes etc), to connect the brake pedal to the booster rod, we had to push the rod forward into the master cylinder, the rod extended too far back to hook up to the pedal.
Doing so also meant we were applying the brakes in the process. (Not a problem at the time since it hadn't been bled as yet).
We've since disassembled the other booster to see if there were/are any adjustments available but cannot find anyway to adjust the rod length.
It's got us stumped! Either we've went astray on the ABS somewhere or it's simply the brake rod to pedal problem. Both cars had working brakes when we started the project...
Any help -suggestions???
