second guess my heads
  • second guess my heads
    I bought these vortec heads cast number 10239906 a couple months ago as some of you might remember. Well today my dad told me to get them a valve job so i went up to Mazza's and they want 120$ to do it. So if i do that id have about 370$ in these things.
    I start to look around online and im seeing that hot rod and a few websites are saying that these heads are garbage and to avoid, but ive heard also that these are supposed to be high flow heads...now im getting confused
    Should i just sell them and buy the brand new 450$ vortec heads from a website? Im starting to think so. What should i do??
    http://www.chevyhiperformance.com/ho...458/index.html
    "For you junkyard hunters, be forewarned that some ¾- and 1-ton trucks came with Vortec heads equipped with a specially hardened exhaust seat that kills low- and mid-lift flow. Casting number 10239906 should be avoided."
    this is a thread started years ago on the same topic, still confused
    http://www.sallee-chevrolet.com/Disc...tml?1089732160
    oh damnit!
    http://www.chevyhiperformance.com/ho.../photo_06.html
    "The easiest way to identify a Vortec head is by the sawtooth pattern cast into the front. Look for casting number 12558062, but avoid casting number 10239906, which has a modified exhaust seat and loses 20 percent of its flow at 0.120-inch lift." IDK what that lift means but i think i will have more than that?
    wait!
    http://www.chevymania.com/tech/vortec.htm
    "They are available under 2 casting numbers 10239906 and 12558062. Both casting are good and performance wise they have no difference."
    I think they did a rewrite on the heads and said the 906 were just as good as the others butnot sure just what I was told I had a set on my 350 s10 an they seemed fine
    sigpic1999 Trans Am Bolt On Car plus Nitrous!
    2009 Yamaha R6
