Man' I hate to be confusing everyone.
The 99 was purchased originally to be a street machine, big block powered and dumping all the fancy GM stuff like computers, air bags etc. Then we fell into the 94 LT1 car deal, and it made perfect since to do the swap instead of butchering the 99.
Our new plan was then to use whatever needed from the 94 so we could use the LT1 engine in the 99. At first we thought we'd just use the computer, engine, and harness firewall forward and the motor from the 94 and with some computer programming bypass or mod what we didn't need and be good to go.
At this point based on what I know are smart fbody guys here who've brought up issues we'd forgotten (OBD1 vs. OBD2 etc), we either have to swap the majority of the 94 harness into the 99 and still deal with the small items in the dash of the 99 not being changed, that are not the same as the 94 had -in essence just swapping the body / chassis between the two cars. Which is a huge amount of work to do properly.
The alternate plan to the above is to treat it like an old school car, utilizing the stock ignition switch as an old style ignition (start, run), replacing the instruments with electric aftermarkets and then reprogramming the computer to only run the fuel injections needs, the air bags needs, AC and possibly the ABS. Making the engine -other than the fuel injection completely independent of the computer. Which would also mean down the road we could change the engine out again for something other.
My question under this scenario is it feasible to do with the 94's computer what it would require? Or do I bite the bullet and do all the work to swap the stuff. I've only got like 3K total in the project to date, a stock v8 bird would have only been a couple grand more to start with.
Advice, thoughts or suggestions?
Thanks!
Chevy
Thanks!
Chevy
