V6 to V8 Engine Swap 4th Gen
This is a sticky topic.
  • #31
    Originally posted by esoteric18 View Post
    which would i want the 3 channel or 4, and as far as the speedo goes when i put different gears in it should throw it off drastically what kinda place recalibrates em
    you will want 3 channel. Any lt1 z28 should have the rear end you are looking for.
    I used to have a v6 car and I did get a 4 channel rear end to work on it.. but I lost my TCS as well as my ABS. On my v6 3 channel car the sensor is on the top of the pumpkin, on the 4 channels like plum nuts said the sensors are at each wheel. 4 Channels also have an extra brake line if I recall, we swapped my v6 stuff onto the 4 channel rear, but the wiring/sensor differences couldnt be changed.
    To correct the speedo for the new gear ratio you can get a tuning program or have a dealer reflash your computer for the new gears.
    -Derek-
    • #32
      my 96 V6 has 2 fans with ac..
      DraftKid
      The best part about buying new tires is burning the old ones the day before
      1996 RS 3.8L ... for now
      • #33
        i did my swap about a year ago. and swapped everything so i can also help out if anyone needs any help. i browsed through here and didnt see much lol. the gauge cluster as far as i know yes you need to swap them
        94 V6 A4>>>>LT1 M6>>>>>>383 M6 13.1 @ 109 2.2 60' Sold/Stripped
        94 Z28 383 LT1 A4 SNAPPED CRANK
        1992 Camaro RS 305 700r4 Convert.
        1986 Dodge Ramcharger 318 Dually Rear, Camo paint. Scrapped
        1993 s10 4x4 5spd 4.3 on 31s awaiting a lift. [COLOR=rgb(0,0,0)]traded for...[/COLOR]
        1998 Jeep Grand Cherokee 4.0 I6 getting 3in lift and 31s within a week or two
        "Life is full of decisions, You make them and don't look back"
        • #34
          thanks for the info on the cluster..
          DraftKid
          • #35
            My car had a transplant before I got it. I have been trying to find out exactly what is needed and what I'm missing. I noticed a lot of stuff that was unplugged, ends cut off etc. When I got it about 4 months ago. Is there any reason someone would have ran a couple new wires to the ECM?......Just curious because mine has a couple running to it but I can't tell where they go. I'm not 100% sure they even used the correct wiring harness on the motor??.....
            Thanks,
            Stephen
