my nieghbor is moving and i would like to buy this 60's truck sbc 350 engine it is just the engine it has been sitting for a long time like probly atleast 7 years in his garage it needs to be completly rebuilt and he asked what would i give for it so i am coming to you what is it worth. it is a 4 bolt main stock 2 barrel.
thank you
I'd say in the 200 range, depending on if he's done anything to the engine or not though. If it's just a stocker 200, If it's built up i.e. aluminum rods, heads, performance intake, steel crank. It could be worth alot more.....
i believe it's completely stock and it has not been covered so all the holes are open and its been sitting on the floor for as long as i have known him i believe. it's pretty rusty and i believe the carb is locked up and i am not sure if you can turn the engine over or not that might be siezed to i am not sure i will check.
Basically the only thing your buying in that case is the 4 bolt main block itself, and possibly the crank. The heads, pistons, rods, intake, carb are probably ancient and obsolete. The 4 bolt main is a good building block though for future projects, just think of it like that, but don't spend over $100 on it.
ok i believe i ended up with a 305 instead of a 350. i dont have a caliper so can someone tell me the size of the bore on a 350 in like inches or something. there is no vin #'s anymore but the sides of the block say 010 and the back of the block by where the bellhousing bolts on the #'s are 3970010. can anyone tell me is this a 350.
thank you
