engine wont fit
  • engine wont fit
    hello
    i have a 1983 camaro z28 with a smallblock v8 carb model and the engine sits to tall for my hood to shut it has a hood with louvers so i don't want to cut the hood is there anything that i can do to make the engine sit lower it has stock engine mounts?
    thanks Dustin
    You might have to get a Cowl hood if anything
      Cowl hoods are kool !!
      **** FEAR THIS ! ***
        i dont have that kind of money. i have to get my car done so that i can drive to get a job. but thank you for your idea
        thanks Dustin
          Try a lower profile air cleaner. I'm assuming this is a different engine and intake/carb setup than stock? Got any more details? You're not giving us much to go on. You could always be a redneck and run it without a hood.
          Wade
            hello
            the motor is a chevy 283 smallblock bored 10 over and it's all built performance but the intake is a edelbrock performer 4barrel intake and it's the same hieght as my stock intake and it has a stock rochester quadrajet from the late 60's and the hood only misses the top of the carb by about 1 inch and i cant find a small enough breather to put on it and have enough air get into it for the engine. here are the only pics that turned out.
            thanks dustin
              i also tried a stock sbc 305 engine with a 2barrel carb and then switched it to a qaudrajet set up and that was also two tall. i have tried mount's out of the late 60's and that did not work ethier and now i tried making my own mounts and that is currently how it is right now and it sit's 2 inches lower than the stock mounts. my car was origanally manufactured with 305 in it and now a v8 won't fit and i don't know why.
              thanks Dustin
