Slap a TT on that thing and it would make around 300 to 400 lol thats the crazy thing about those engines
New 350 going into the tuner
ebay 3000 was the average.. there were some for less, i searched for a while because i was gonna swap one in mine. granted they were used...Originally posted by TransAmRocker View Postwhat you talkin about, everwhere i looked ls1s were 8k and i got this engine for 2500-Derek-
yea, i coulda got a used one and a 6 speed transmission for 3100 outta the paper but it had 130k miles on the engine. The 350 I did get tho is a recondition block or w.e so its stress tested and all that good stuffIt's easier to make a 3rd gen faster than to make a 4th gen look good
New parts include:- Sealed Power hypereutectic pistons and rings
Competition Cams performance camshaft
Fel-Pro gaskets
Clevite 77 rod, main and cam bearings
Melling high-volume oil pump, pickup screen and driveshaft
Valve guides
Pioneer harmonic balancer, flexplate, performance valve springs, brass freeze plugs and bolts
Melling push rods
Double-roller timing set
EDELBROCK Performer aluminum TBI intake manifold
Chrome timing cover, valve covers, oil pan, dipstick/tube and breather
GM valve locks/retainers
- Engine block, cylinder heads and crankshaft thermally cleaned, shot-blasted, and Magnafluxed
All crankshafts and reground, oil holes chamfered, and micro-polished
Thorough cleaning including all oil galleys, engines are absolutely clean inside and out
All blocks are bored and honed using torque plates
New cam custom fitted
Connecting rods fitted with new bolts and resized
Rotating assembly Sunnen computer balanced (balance sheet included)
Cylinders heads completely remanufactured, including new guides, new seals, and performance 3-angle valve job.
Every engine custom-built (no assembly line) by professionals
Engine painted with high-gloss engine enamel
Finally found it on ebayIt's easier to make a 3rd gen faster than to make a 4th gen look good
\,,/>_<\,,/
- May 11th, 2006
- 10130
- Mark
- 2023 Malibu, 2022 Explorer
- Winston Salem, NC
Hope your gonna clean that bay up some first. Good luck with the swap. Should be awesome once it's done.
yea, im gunna ALTEAST paint it if not cut out the rust and patch it upIt's easier to make a 3rd gen faster than to make a 4th gen look good
yea, we just sprayed it so that the rust wouldnt show, we are gunna strip down the other side later on and finish it lolIt's easier to make a 3rd gen faster than to make a 4th gen look good
