383 Stroker Build in 1988 IROC
  • 383 Stroker Build in 1988 IROC
    Well, a buddy of mine form work (Dan) is wrapping up his build today. He has a hugger orange 88 IROC that came with a 305. He has saved up $6000 since his first job to buy all parts brand new. He is now a senior tech at Valvoline at only 18, so that is where funding has come from.
    A friend of ours, Nick, has a black 96 T/A M6 with a cam swap, K&N FIPK, Pacesetter longtubes and ORY, and flowmaster catback. A few days ago, we were putting Dan's top end of his motor back together. He needed the rockers adjusted properly, so Nick having experience went ahead and tightened them down. The problem is, he overtightened them after thinking they were hydraulic, so he did one full turn after snug instead of a 1/4 turn as they should be. She wouldn't start that night, so a couple days passed until another guy from work (Henry) could come over to help.
    Yesterday, Henry and I are messing around with everything with Dan. We primed the motor, put the valve covers on, hooked up the distributor, and she wouldn't turn over. We found out the starter was wired backwards, so we fixed it and got the motor to turn over. She fired and ran on 6 cylinders, spitting fireballs out of the carb, so that obviously told us the timing was off. It sure is loud as hell, though. Stock car loud, coming out of the currently open headers. Because the timing was off though, we shut her down and opened the valve covers to readjust the rockers. When we went to loosen them, Henry noticed it was far too tight since it was impossible to even turn the motor by hand with a ratchet to get it back to top dead center. A few lucky bumps of the key landed the motor at TDC, so we started adjusting. Dan gets to a cylinder and feels for the pushrod to finger tighten it, and finds that there is nothing there. We popped off that rocker and found the pushrod had dropped down, indicating it was probably bent. We found another like it on the other side of the motor. A magnetic rod pulled the pushrod out and we actually found that two of them were broke. Dan was heartbroken and angry since spending that kind of money at 18 is very hard.
    Today at work, Henry brings in some pushrods from his old 383 project, and the IROC is back in business. I am leaving right now to go help get the new pushrods, get the motor to fire on all cylinders, idle her for 10 minutes to break her in and seat the piston rings, and then we're hitting the road. I'll get pictures if I get the chance. Wish us luck!
    Here's what we're working on:
    1988 IROC Z Hugger Orange
    383 Stroker w/ some forged pistons (not sure what he used, he's keeping some things secret), comp cam, comp cam pushrods, crane cam rockers, edelbrock heads and intake, edelbrock carb (soon to replaced with Holley). I don't know much more than that. He's Mr. secretive about this. I know he's expecting more than 400 at the wheels.
    Turbo 350 Transmission rebuilt w/ manual valvebody, B&M T-Handle shifter and B&M trick shift fluid
    Weld draglites with Mickey Thompson Sportsmans and Skinnies
    Racing seats
    ShiftLite dashmount Tach
    Much more to come as I find out! I have a few f-body friends that haven't yet joined the community, so more is to come!
    1997 Red T/A (SOLD)
    WANTED: LT1/LS1 and T56 (preferred) T/A!
    Car sounds awsome!!
      If its a Flat Tappet cam I sure hope you have read this article and understand it. http://www.mifbody.com/vbulletin/showthread.php?t=8683
      I would hate to see all that money wasted over not using the RIGHT OIL!
        she's running like a champ today. he's out driving her right now. and we used castrol gtx 20W-50, so no worries!
        1997 Red T/A (SOLD)
          Very cool, that's unbelievable about a simple 1/4 turn compared to 1 full turn makes that much of a difference! Glad I don't mess around with the mechanics yet. Got too much to learn.
            yeah, its intimidating. i don't even know THAT much, henry was the main man. he's got a few projects of his own.
            and actually after i started the thread and got to dan's, i noticed 4 pushrods were laying out instead of 2, because in addition to the 2 that broke in half, another 2 were bent. henry saved the day not only on the build, but on the parts too.
            1997 Red T/A (SOLD)
              She's running on all 8, and we got her all dialed in with a few turns of the distributor, adjustment of the fuel pressure, and a few adjustments of the rockers. After we let it idle for a while at 1500 to seat those rings, the motor got a knock when Dan took it around the block, so we popped the valve covers and tightened down any loose lifters. We did this about 3 more times just to be safe.
              She is VERY loud. Stock car loud, coming out of open headers. Dan is putting some Dynomax on it on Thursday when the check rolls in. At this point though, everything is running awesome. I'll get some pictures and have him join the party here!
              1997 Red T/A (SOLD)
                sounds fun! can't wait to see some numbers.
                88' Trans Am 350 TPI
                  Sounds like a Hell of a car..
                  What rear does he have in it?
                    and video!!!
                      stock 10-bolt, soon to be a ford 9 inch.
                      and pictures and videos soon!
                      1997 Red T/A (SOLD)
                        Man u write some long posts !!!
                        **** FEAR THIS ! ***
                          haha, i know. most of what i say nobody pays attention to and then gets upset with me about it. and this is the only community where it happens...hrm.
                          ill get some pictures up shortly. bare with me.
                          1997 Red T/A (SOLD)
                            think i have seen this car down bay road...if so awesome looking car....
                            94 Pontiac Firebird...Stock with flowmaster american thunder dual cat back system
                              What's the latest on the Roc
                              The first Gen started it all!!!
                              67 CAMARO RS AND A SEXY WIFE
