lt1 wiring anyone?
  • lt1 wiring anyone?
    The motor is a 1995 lt1 OBD 1
    The car it is going in to is a 1993 camaro with a tube k-member and th 400 trans.
    If u could just get it runing that would be a plus.lol.
    I am wiling to tow the car or you can come down. The car is in bellville,mi zip 48111 .
    Its time to get the show on the road.
    also i have pics on hand if needed.
    1993 Camaro
    th-400
    3.4 to lt1 swap
    stand alone wire harness
    coming soon ( just ask)
    home made S400 frount mount turbo on the way
    397ci 9:1
    Goal 750rwhp+
    are you using an OBD1 computer or a 93 Speed Density setup? im not going to be much help with the wiring itself but i think the best setup for you would be to run an OBD1 M6 computer, and either run a TV cable to your TH400 or make it a manual valve body. (id go with the manual valve body personally)
      I have no problem with the hard parts with the car. thats the easy part.
      Also the motor is mass air flow OBD 1. The ECU , wire harness, and lt1 motor is all out of the 1995.
      Also the ECU has been reflashed for a M6.
      All i need is wiring help. thanks
      1993 Camaro
      th-400
      3.4 to lt1 swap
      397ci 9:1
      Goal 750rwhp+
        hello all
        1993 Camaro
        th-400
        3.4 to lt1 swap
        397ci 9:1
        Goal 750rwhp+
          We are located right down I94 in Clinton Twp. Please feel free to give me a call. We can make an appointment to take a look at your vehicle. We have wired various vehicles, so it shouldn't be to much of a problem.
