pop ths shifter off and fill from inside. lol. Not reallt that easy unless your stuff is all apart. But like matt said there is a fill hole on the side. have fun.
And another thing.....when I gun the motor, I want the whole world to think it's coming to an end. -Homer Simpson
tony there is no other way. you either tear off the shifter and fill it from the top or you pull the fill plug and do it. I usually use a piece of hose attached to the oil bottle to help get into that tight spot.
