My 9" Install
  • My 9" Install
    Well I finished my 9" on friday night just in time for the GV show
    I figured I would post on how I did it incase any one had any questions on how too do it or how dificult it was.
    1-10 I would give this a 5, if you have someone to help you could call it a 3.
    A point so you don't have to unhook you breaks is to unhook the holders and get all the lines free then you can set them right on the floor.
    With your car supported on jack stands:
    Get the rear on a jack with wheels so you can manuver it around.
    The 1st thing I did was hook up the Torqure arm and getthat set 1st that way the rear don't tip down.
    Hook up the LCA's next, this way you don't have to fight the rear side to side .
    Get your bolts and nuts in and hand tight.
    Don't tighten them up, you need to have a load on the rear so they don't bind.
    Set your springs on and jack up the rear about 1" at a time checking the springs to make sure they don't bind on something.
    Get the rear up high enough to mount the shocks and get them tight, this will hold the rear up so you can remove the jack.
    For 20.00 you can get new Energy SUspension sway bar links, well worth the money.
    Slide your sway bar ends on to the sway bar links and get them hooked up but not tight.
    Then hook up your sway bar to the rear and get the brackets on the rear but don't tighten them.
    Hook up your panhard bar and tigten it.
    Then tighten your sway bar brakets on your rear an then tighten you sway bar end links.
    Hook up all your break lines, calipers and mound your tires.
    Put ramps under the rear tires and drop the car down.
    Make sure you check your springs as you start to put complet weight on the suspension.
    Now tighten your LCA's.
    Hook up your drive shaft and you are ready to go
    Any questions just ask.
    kyle.
    -Homer Simpson
      Sorry, no pics with this one
        Cool man...what ratio did you go with?
          Thats pretty much how i did it too, wasn't too bad
          1996 CAMARO Z\28 M6
            Originally posted by 1bad83ta View Post
            kyle.
            Kyle, if you woulda taken pics, this would be one for the archives. There seems to be so many people that are going to a different diff, this would have been a perfect format for a swap.
            So, what we need you to do, is take out the 9 inch and re-install the original...ah, nevermind...j/k...
            If you have some installed pics, those would work too.
              Yes, I can get some installed pics.
              I have to do a safty check on everything to make sure it's still tight.
              I'll get pics sometime this week and post them up.
              James I went from 3.23's to 4.10's with a locker
                Thanks Kyle,
                I should have that rear end in by the end of the month with 4.10 gears. Hopefully the posi unit is in good condition still. Should be a cheap swap. When it blows I won't have to much money into it. I can take some pics when I install my rear if you guys want. I'm also installing Koni shocks. removing the rear spring rubber Isolator. Installing a rear end girdle, adding relo brackets. Hopefully find someone with a welder to box in my stock control arms.
                1997 Trans Am
                www.fquick.com/transampimp
                  mMmMmMmmmmm 9"
                  1998 Camaro SS Bullseye Turbo
                    *****in...that should make a huge difference!
                    I hope my 9" gets done soon......I opted for 3.90
                      i need a 3.23 highway gear for mine
                        Doin the rear too...
                        Started my "old school" rear end swap today...have the Detroit Speed quadra-link rear but the original 3:73 posi and Muncie 4 speed cheated both ends of engine output. Going with a Tremec 6spd w/hydraulic clutch and a 9" from Detroit Speed with all the brackets for the 4 link in place.
                        Bumping up to 4:10 posi to help rip the skins and maybe even push me over 10 mpg...Oh shit, call Al Gore on me!
                          Originally posted by Fuego396 View Post
                          Started my "old school" rear end swap today..maybe even push me over 10 mpg...Oh shit, call Al Gore on me!
                          I was lucky to get 10mpg when I had my 3.23's and that's no lie, I just have to get my tune redone big time.
                            Nice to see you back Mike!
