9" Owner Please
  • 9" Owner Please
    I have finaly got my 9" done and we are ready to put it in
    I have a few questions:
    I was wondering what you had to do with your drive shaft?
    Did you have to get a new one or did you have your stock one shortend?
    And what did you have to do with the tunnel, did the 9" fit or did you have to "modify" it?
    The 9" came out of a 2000 Z28.
    driveshaft should be the same length you'll just need the 1350 yolk for your stock one. i just went ahead and replaced my good for nothing aluminum shaft with a steel one.
    the 9" should fit in the tunnel, your torque arm or torque arm mount might hit the tunnel some, you can eaither pound it out some with a big hammer or just let it "clearance" itself out.
    1998 Camaro SS Bullseye Turbo
      That's the part that comes out of the diff right.
      What about U-Joints??
        this is what you'll have to replace on your driveshaft, the stock one, for one of these...
          Sweet!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
          Maybe I'll get it in this week in time for the Opening day at 131.
          I hope the weather man is wrong because 40* is to cold for racing.
            Oh...You meant a 9" Rear-End.... lol
            Holley 650cfm Double Pumper
            Edelbrock Performer-Plus Cam
              So that means you will have a 10 bolt on your hands that will need a new home?
              1997 Trans Am
              www.fquick.com/transampimp
                I have to go pick upy 9" too, just don't have much time to go pick it up cuz of my retarded work schedule
                1996 CAMARO Z\28 M6
                  Sean from CARS is putting a 9inch together for my car this week.
                    damn drop that $$$$$
                    2011 Cadillac CTS-V sedan black raven 6spd
                      You gotta pay to play. Zack you need to update your sig bro.
                        yeah zack
                          there i changed it...you 2 happy now? im not a fraud anymore....
                            most of the better torque arms have two sets of holes. You need to use the inner set and may have to trim the outer set off to be able to use the inner set
                            If you have a 1350 yoke you need Napa pn# 240-0447 (used to be 447) to be able to use your stock driveshaft
                              Lol....yeah but it's a *****in Death Trap! Any tickets yet?
