Well we just brought the rear i bought last fall into our shop to do the swap tommarrow and came accross a snag. I guess I have a 3 channel rear on the bird now with 3.08s,abs,traction control and no posi. So I bought a rear off an 02 anniv. SS with 3.42s lsd and traction control. little did i know the SS was a 4 channel. I was wondering has anyone done a swap from 4 channel to 3 or is that even possible? or is there any car that came with a 3 channel, abs, traction control, posi, and 3.42s stock? otherwise its lookin like I will have to just buy gears and posi and pay to have them swapped in
4 channel to 3 channel
haha i was gonna do some search'n for ya on LS1tech, but i see you're one step ahead young grass hoppa!
you can do like that one person posted over there, or just do the ABS delete like i did in my car and throw it in!
1998 Camaro SS Bullseye Turbo
InActive Member
- October 30th, 2005
- 128
- Jeff
- 2002 SCCA T2 Z28
- White Lake, MI
- Suspension Engineer
A 3 channel car is ABS only, while a 4 channel is ABS and Traction control. My car is a 3 channel with a 3.42 posi. It doesn't have traction control. I am pretty sure you can't have a 3 channel car with TCS.Originally posted by redfbirdv6Or is there any car that came with a 3 channel, abs, traction control, posi, and 3.42s stock?
Jeff
2002 SCCA ITE Z28
incorrect, my dad is an auto mechanic and we looked and its definately a 3 channel, it is just that i have the sensor for traction control at the top my of differential instead of at each wheel like the 4 channel does, or something to that nature. if that were the case then i would be fine in swaping the new rear in lolOriginally posted by fireball25f500A 3 channel car is ABS only, while a 4 channel is ABS and Traction control. My car is a 3 channel with a 3.42 posi. It doesn't have traction control. I am pretty sure you can't have a 3 channel car with TCS.-Derek-
Looks like you got it figured out. But from my understanding, you cannot "convert" 4 to 3 channel or vice versa. Due to the fact that the sensor read differently and it's an entirely different system. 4 channel is more advanced by having wheel speed sensor reading individual wheel speed versus 3 channel read off the top of differential for speed reading and compare it to the front wheel. The computer and its programming is not even close.
bah anyone need a four channel rear with i believe like 10k miles on it?Originally posted by willascLooks like you got it figured out. But from my understanding, you cannot "convert" 4 to 3 channel or vice versa. Due to the fact that the sensor read differently and it's an entirely different system. 4 channel is more advanced by having wheel speed sensor reading individual wheel speed versus 3 channel read off the top of differential for speed reading and compare it to the front wheel. The computer and its programming is not even close.-Derek-
