has anybody used them in the past? I think I am going to use them to fix the 4l60e in my vert. Supposed to bring it in next saturday. Guy seems to know about GM automatics.
C3 automotive in Brighton
Post Whore
- August 16th, 2007
- 2881
- Jim
- Traverse City, MI
I've rebuilt the 4l60e twice in the past 6 months, it's really not that bad. Also there is great support on LS1tech and a local moderator(he lives in Ann Arbor) on there that is very knowledgeable and has tools/all of the documentation you could ever want that he is willing to share.
Post Slut
- December 9th, 2011
- 5919
- Michael H
- Lowell, MI
- Meat Processor
It's not bad to do it yourself, had to make a couple tools to do it though. In the long run it was a great learning experience and I saved about 400...but I recommend having it done and get a written warranty. Found out my valve body was worn out at the TCC bore after all that work. I have the parts to fix the issue but no desire to tear back into the trans.
Warranty would definitely be important. I feel the same way about it though - I'm sure I could rebuild an auto trans - but I really lack the time. And if I do it, and it fails...I'm on the hook to do it all again.Originally posted by hoogiesngrinderz View Postbut I recommend having it done and get a written warranty.
Pretty sure I'll go the route of having someone build my 4T45E, and warranty the work, than do it myself.Gone but not forgotten: 1986 Chevrolet Camaro IROC-Z
getting too old for swapping transmissions. After I did my last one I swore I'd never do it again. Now if I had a hoist and trans jack, yeah, maybe. but I don't so, outsourced.When in doubt, Whip it out !
Post Slut
- 5919
- Michael H
- Lowell, MI
- Meat Processor
Whoever does it, ask that they use a NEW reverse drum and a wide 2/4 band, preferably non kevlar like an Alto Red carbon. Not a fan of the Z Pak clutches either, I would use Borq Warner Hi-Energy
Originally posted by hoogiesngrinderz View PostWhoever does it, ask that they use a NEW reverse drum and a wide 2/4 band, preferably non kevlar like an Alto Red carbon. Not a fan of the Z Pak clutches either, I would use Borq Warner Hi-Energy
^Agreed. Also make sure they replace all of the electronics (That's why I rebuilt mine twice). And any good builder should replace the sun shell with at minimum the beast sun shell but the sonnax smart shell is preferred. My first rebuild had a z-pak in the 34 but I am now running the BW High Energy.
I can help with a component list if you'd like. I've learned a decent amount in the past 6 months.
Originally posted by DynoDave View PostHmm...lots of good tips here. Guess I'd better subscribe for future reference.
Dave, below is a link to my rebuild thread that has most of the info I learned and outlines both of my rebuilds. There is a lot to read but a bunch of really good info.
http://ls1tech.com/forums/automatic-...ld-thread.html
-Vinnie
