shifter problems after engine swap
  • shifter problems after engine swap
    ok guys, im having an odd problem, i pulled my ls1 and 4l60e out of my camaro for a 5.3l swap, well now everything is back in and i put some new wheels on it today and when i lowered the car to tighten them i noticed i could roll the car more then normal, so i look up inside the car and notice its in park, and yet i can push it like its not, so i got in turned the key over and trying to pull it out of park felt like trying to turn the steering wheel of a car with no power steering,
    not sure if i need to adjust the shifter cable or need another one? cause i did forget to disconnect the transmission shift linkage when i went to drop the trans and it did get some weight of the trans on it, but once i noticed it i lifted the trans as quick as i could, could i have damaged the cable??
    and if so does anyone have a 1995-2002 4l60e shift cable??
    1993 camaro z28 396 CID stroker custom paint, geared stalled, tied, lowered.
    1998 camaro z28 5.3l swap (currently being built) stock other then HV, HP ported ls6 oil pump, ls6 intake, and lightly worked heads. And I mean very lightly. Oh and has a k&n open filter cold air intake.
    Broken shift cable is likely. I've broke one, Peter broke one during his engine swap, pretty common problem
      Yeah I went thru 3 already trying to find a good one. Finally found me one, all is well again, thanks guys, but hoogie, word on the forum is you can tune 1998 ecms? I have one I need tuned if you're interested and able?
        I have access to EFILive, and I'd only be able to do a basic tune...but it should be able to get you close.
