This is out of a 1999 ls1 camaro..will it work on my 1995 lt1 trans am ?
I have 2 4l60e's 1st one is stock was slipping on the 2-3 shift when using nitrous, The 2nd one Built to 4L65e specs, 5 pinion planetary's, the beast sun gear shell, alto red clutches, Hughes Performance deep aluminum pan, all quality Sonnax parts, Transmission is rated to around 700hp, Trans has Less than 5000 miles on it. But the built tranny is giving a solenoid stuck code. So someone could change the solenoids from the 1st to the 2nd. went to a th400 so these are just stitting collecting dust. My loss your gain.Also has a midwest converter nitrous converter.. thanks $800
