I lost 3rd and 4th gear in my 4l60 last night on the way home from milan so I'm looking to rebuild the trans. The car is a H/C/I LS1 with a 4k stall. The only modifications to it were a trans go shift kit. I'm looking for a budget oriented rebuild that will have stronger than stock components. I plan on rebuilding it myself so I am just looking for the hardware.
Ended up going with this setup http://www.trutechtrans.com/TT4L60E-...RE-Basket.html along with a Sonnax Smartshell. The company I purchased from has great tech support and I found a local member on LS1tech that has a lot of knowledge based on the 4l60e so I feel confident in building it right.
Yep [MENTION=3959]pnyklr[/MENTION] . I will be using these videos as reference: http://www.transmissionbench.com/4L60Evideos.html and I have the company I bought the parts from providing 24 hr tech support as well as a local member from ls1tech.
nj346 If you need technical help or any misc items look up my shop in Warren. (I live in troy) I stock just about everything imaginable for 4l60e's and 'sure I can save you some grief if you get into a pinch. Rich Bewick
Rich thanks for the feedback. I actually just got back from the test drive and everything went well. If I decide to tear the trans apart again this winter to make it bullet proof, I will be in contact. Overall build ended up being pretty stout IMO. I did the sonnax smart shell, HD 2-3 shift valve, pump spring upgrade, etc. The only things I could really do is maybe upgrade the planetaries and the input and output shafts if I decide to go to crazy power levels in the future.
