Not physically, just any hints to make things easier. For instance, how do you get to the 2 top bell housing bolts? From above or below? What about the dip stick tube? remove it befor trying to move the trans back? I am going to try and only remove enough to just slide it back to swap out the torque converter.
So far the torque arm , drive shaft , starter, exhaust bracket, inspection cover, shift linkage, speedo wire and torque converter bolts are off.
Tomorrow bell housing bolts, cross member, transmission lines, dipstick tube..... anything else?
So when I install the new converter, fill it first? How far?
Oh I am waiting for a precision industries 245mm billet 3000 stall triple disk, from Detroit gear.
