Factory Aluminum Driveshaft?
  • Factory Aluminum Driveshaft?
    So I have two aluminum driveshafts, one of which I just bought in an effort to try to fix a driveline vibration. Both individuals I bought these driveshafts from claim they are factory driveshafts (and I believe them).
    Question is, whats the difference? Were there two part numbers GM used? Does one of these not look factory? There isnt any particular reason i want to know, just curious.
    curious...SUBSCRIBED.
    LTXtech.com is my DRUG!
    sigpicLarry
    1996 Z28: M6, Procharged 385. (Member of the $30k+ club)
    1985/1996 Corvette "Grand Sport."
      Believe they are both correct . A4 damper, m6 no damper
        I have the bigger looking one on my car now, pulled it from my neighbors 1999 Camaro SS A4.
        1996 Base Model
        +2 cylinder mod
          Whats the technical reason behind that? Is there any reason not to interchange the two?
            Posting from under my Trans Am...
            Mine is the same as the bigger/cleaner one.
            As you know, 2000 Trans Am M6
              I have removed two aluminum driveshafts from M6 cars and they both had the dampner.
              Do they both have a three rivers sticker on them?
              I have two aluminum driveshaft at the shop and they both have the dampner. They also have the plastic U-joint piece that you have to melt to remove the U-joint.
                Thanks Fred, always going the extra mile
                I will check this the next time I am at the garage.
                  interesting, i need to replace my driveshaft. looks like it was spun up and dropped on a drive shaft loop. engraved all the way around. rather strange.
                  subscribed.
                    just found this . IDK
                    http://www.thirdgen.org/techboard/hi...riveshaft.html
                      Maybe smaller one is from v6 and larger v8.
                        Nah ive owned V6s, they didnt come with aluminum driveshafts not even the Y87 performance cars.
                        I think Larry is closest to the answer. It looks like the smaller one is the earlier 3rd gen / 1LE drive shaft and from the sounds of it is actually the stronger of the two. Hmm.
                        I wonder if i can remove the damper by the yoke?
                          correct me if i am wrong, but the v6 cars came with a 2 piece drive shaft correct?
                            i dont think the dampner will be a bad thing,
                              its additional rotating mass is it not?
